Author Topic: Bug when saving embedded PNG images  (Read 647 times)
elmobarnett
v. 3.3.7252, Windows 10Pro x64
if I try to save an embedded cover from the Track Informations Panel (right click on the artwork > Save Picture To...) MusicBee rename the extention *.jpg even if the file is *.png
Preferences > Tags (1) > artwork storage > coy to the same folder as the music file and name as:
In the template field set the extension in the template to .jpg (or .png if that's what you want.)
