Author Topic: Selecting portions of your full library to shuffle  (Read 479 times)
sghorwitz
Is there a way to tell the full library shuffle NOT to include particular tracks or albums? I have deleted some material from my library yet shuffle still seems to pick it up.
On iTunes, for example, you could check or uncheck a box to include or exclude tracks from full library shuffle. Is there an equivalent?
Thanks.
Hi, welcome to the forum!
Check out the ban track option under settings in the tag editor. Although if you've actually removed things from the library, they should NOT be playing. I suggest double checking that it's not hanging around in the library.
