Author Topic: MusicBee sync question - duplicate checking  (Read 1394 times)
splatt
I've been trying to sync MusicBee to my phone via USB, and it seems that  it doesn't check to make sure that it's not creating duplicates - it just sends everything right on over regardless of if MusicBee has previously synced the song or not. This when I just barely synced the device 5 minutes ago and haven't even disconnected the device. Is that how it's supposed to work?
I don't experience that issue.
What version are you using?
You might want to try the portable version.
splatt
I might try that. I discovered I was tapping "PTP" instead of "File transfer" on my phone. switched that and it seemed to fix itself
But there is a second issue that keeps coming up as well - It keeps telling me that the storage folder no longer exists and may need to be changed in the device sync preferences.
