Author Topic: Having certain music types in own folder.  (Read 460 times)
ndg93
I was wondering if it would be possible to have musicbee organise music of a certain type in its own folder e.g:
I have a lot of soundtracks and instrumentals in my music library and would like to have all those songs put in their own folder (like the way itunes puts compilations in a separate folder). I have the followong text "Soundtracks / Instrumentals" in the comments section of each of the song tags that are either Soundtracks or Instrumentals.
So all my other music would be organised like this
Music/Artist/Album
and my Soundtracks & Instrumentals be organised like this
Music/Soundtracks & Instrumentals/Artist/Album
I hope this is possible.
Thanks in advance for any help.
Cheers.
Hi, welcome to the forum!
This is pretty easy to do with MusicBee. I suggest creating a custom tag for this rather than using Comment (you can copy your existing tags over using the Additional Tagging & Reporting Tools plugin), or maybe use Grouping if you're not using it for something else. Here's an old thread on a similar situation, which might help: https://getmusicbee.com/forum/index.php?topic=21363.0
Also be sure to check out the wiki if you need more help with templates, custom tags, and so on.
