Author Topic: MusicBee auto closes at the end of a DSD song  (Read 11950 times)
frankcreed
Hi Steven,
Just so that I'm providing feedback on the correct debug version, this info is for ver 3.3.7248 P.  Same symptoms (crash at end of 1st DSD file (DSD128), with DSD64 file next in playlist
Here is the log info:
11/5/2019 4:46:55 PM - E:\Frank's Music\:Thread was being aborted.
11/5/2019 4:49:55 PM - init chans=2
11/5/2019 4:49:56 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False,decode=False
11/5/2019 4:49:56 PM - set raw streaming=False,current mode=PCM
11/5/2019 4:50:08 PM - E:\Frank's Music\:Thread was being aborted.
11/5/2019 4:50:08 PM - close stream=False
11/5/2019 4:50:08 PM - close stream handle=0
11/5/2019 4:50:08 PM - Stop1=True
11/5/2019 4:50:08 PM - stop 0
11/5/2019 4:50:08 PM - assign channel before=0,after=0,mode=PCM,started=False
11/5/2019 4:50:08 PM - assign channel paused
11/5/2019 4:50:08 PM - stop: before=False
11/5/2019 4:50:08 PM - stop done
11/5/2019 4:50:08 PM - dispose
11/5/2019 4:50:08 PM - reset channels=0
11/5/2019 4:50:08 PM - reset channels done
11/5/2019 4:51:37 PM - init chans=2
11/5/2019 4:51:38 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False,decode=False
11/5/2019 4:51:38 PM - set raw streaming=False,current mode=PCM
11/5/2019 4:52:17 PM - close stream=False
11/5/2019 4:52:17 PM - close stream handle=0
11/5/2019 4:52:17 PM - Stop1=True
11/5/2019 4:52:17 PM - stop 0
11/5/2019 4:52:17 PM - assign channel before=0,after=0,mode=PCM,started=False
11/5/2019 4:52:17 PM - assign channel paused
11/5/2019 4:52:17 PM - stop: before=False
11/5/2019 4:52:17 PM - stop done
11/5/2019 4:52:17 PM - init=-2147483641,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/5/2019 4:52:17 PM - set raw streaming=False,current mode=DOP
11/5/2019 4:52:17 PM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 4:52:17 PM - play=False,output=0,stream in mixer=False
11/5/2019 4:52:17 PM - play is paused=True
11/5/2019 4:52:17 PM - assign channel before=0,after=-2147483641,mode=DOP,started=False
11/5/2019 4:52:17 PM - assign channel:: chans=2,2; freq=352800,0
11/5/2019 4:52:17 PM - assign channel set format and rate
11/5/2019 4:52:17 PM - assign channel undo pause
11/5/2019 4:52:17 PM - assign channel done
11/5/2019 4:52:17 PM - play startedTrue
11/5/2019 4:55:18 PM - init=-2147483638,source rate=2822400, remove silence=False,is tempo=False,decode=False
11/5/2019 4:55:18 PM - set raw streaming=False,current mode=DOP
11/5/2019 4:55:22 PM - remove eos 2=-2147483641
11/5/2019 4:55:22 PM - remove eos done
11/5/2019 4:55:22 PM - close stream=False
11/5/2019 4:55:22 PM - close stream handle=0
11/5/2019 4:55:22 PM - is same settings:: chans=2,2; freq=176400,352800
11/5/2019 4:55:22 PM - Reset5
11/5/2019 4:55:22 PM - reset -2147483641
11/5/2019 4:55:22 PM - assign channel before=-2147483641,after=0,mode=DOP,started=True
11/5/2019 4:55:22 PM - assign channel paused
11/5/2019 4:55:22 PM - reset done
11/5/2019 4:55:22 PM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 4:55:22 PM - play=False,output=0,stream in mixer=False
11/5/2019 4:55:22 PM - play is paused=True
11/5/2019 4:55:22 PM - assign channel before=0,after=-2147483638,mode=DOP,started=True
11/5/2019 4:55:22 PM - assign channel:: chans=2,2; freq=176400,352800
11/5/2019 4:55:56 PM - init chans=2
11/5/2019 4:55:57 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False,decode=False
11/5/2019 4:55:57 PM - set raw streaming=False,current mode=PCM
would you mind doing another test where the sample rate is the same? eg. have the same song twice in sequence
lux1o
same album same sample rate same song same musicbee crashes
can you post the error log as per the instructions above?
frankcreed
Hi Steven,
I got the same MB crash with having the exact same song twice in my test playlist.  Here is the error log:
MB 3.3.7248 P
11/6/2019 3:54:51 PM - E:\Frank's Music\:Thread was being aborted.
11/6/2019 4:07:35 PM - init chans=2
11/6/2019 4:07:36 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False,decode=False
11/6/2019 4:07:36 PM - set raw streaming=False,current mode=PCM
11/6/2019 4:10:28 PM - close stream=False
11/6/2019 4:10:28 PM - close stream handle=0
11/6/2019 4:10:28 PM - Stop1=True
11/6/2019 4:10:28 PM - stop 0
11/6/2019 4:10:28 PM - assign channel before=0,after=0,mode=PCM,started=False
11/6/2019 4:10:28 PM - assign channel paused
11/6/2019 4:10:28 PM - stop: before=False
11/6/2019 4:10:28 PM - stop done
11/6/2019 4:10:28 PM - init=-2147483641,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/6/2019 4:10:28 PM - set raw streaming=False,current mode=DOP
11/6/2019 4:10:28 PM - set attrib=BASS_ATTRIB_VOL=1
11/6/2019 4:10:28 PM - play=False,output=0,stream in mixer=False
11/6/2019 4:10:28 PM - play is paused=True
11/6/2019 4:10:28 PM - assign channel before=0,after=-2147483641,mode=DOP,started=False
11/6/2019 4:10:28 PM - assign channel:: chans=2,2; freq=352800,0
11/6/2019 4:10:28 PM - assign channel set format and rate
11/6/2019 4:10:28 PM - assign channel undo pause
11/6/2019 4:10:28 PM - assign channel done
11/6/2019 4:10:28 PM - play startedTrue
11/6/2019 4:13:29 PM - init=-2147483638,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/6/2019 4:13:29 PM - set raw streaming=False,current mode=DOP
11/6/2019 4:13:32 PM - remove eos 2=-2147483641
11/6/2019 4:13:32 PM - remove eos done
11/6/2019 4:13:32 PM - close stream=False
11/6/2019 4:13:32 PM - close stream handle=0
11/6/2019 4:13:32 PM - is same settings:: chans=2,2; freq=352800,352800
11/6/2019 4:13:32 PM - play=False,output=-2147483641,stream in mixer=False
11/6/2019 4:13:32 PM - play is paused=False
11/6/2019 4:13:32 PM - assign channel before=-2147483641,after=-2147483638,mode=DOP,started=True
11/6/2019 4:13:32 PM - assign channel:: chans=2,2; freq=352800,352800
11/6/2019 4:13:32 PM - assign channel set format and rate
11/6/2019 4:13:32 PM - assign channel undo pause
11/6/2019 4:13:32 PM - assign channel done
11/6/2019 4:13:32 PM - play startedTrue
11/6/2019 4:13:32 PM - set attrib=BASS_ATTRIB_VOL=1
11/6/2019 4:13:50 PM - init chans=2
11/6/2019 4:13:51 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False,decode=False
11/6/2019 4:13:51 PM - set raw streaming=False,current mode=PCM
according to that log the track played twice - once at 4:10:28 and again at 4:13:32 where the last logged entry is 20 seconds later
So can you confirm it definitely crashed at the start of the 2nd song. Also i noticed the last entry, the mode had switched back to PCM - was that track a non-dsd file?
frankcreed
Hi Steven,
the song in question is 3:04 long, which explains the 4:10:28 and 4:13:32 timestamps (I think).  It definitely crashes at the beginning of the 2nd song.
I think the last entry in the log file was for playing an mp3 file for "regular" listening :-).
11/6/2019 4:57:54 PM - close stream=False
11/6/2019 4:57:54 PM - close stream handle=0
11/6/2019 4:57:54 PM - Stop1=True
11/6/2019 4:57:54 PM - stop 0
11/6/2019 4:57:54 PM - assign channel before=0,after=0,mode=PCM,started=False
11/6/2019 4:57:54 PM - assign channel paused
11/6/2019 4:57:54 PM - stop: before=False
11/6/2019 4:57:54 PM - stop done
11/6/2019 4:57:54 PM - init=-2147483641,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/6/2019 4:57:54 PM - set raw streaming=False,current mode=DOP
11/6/2019 4:57:54 PM - set attrib=BASS_ATTRIB_VOL=1
11/6/2019 4:57:54 PM - play=False,output=0,stream in mixer=False
11/6/2019 4:57:54 PM - play is paused=True
11/6/2019 4:57:54 PM - assign channel before=0,after=-2147483641,mode=DOP,started=False
11/6/2019 4:57:54 PM - assign channel:: chans=2,2; freq=352800,0
11/6/2019 4:57:54 PM - assign channel set format and rate
11/6/2019 4:57:54 PM - assign channel undo pause
11/6/2019 4:57:54 PM - assign channel done
11/6/2019 4:57:54 PM - play startedTrue
11/6/2019 5:00:55 PM - init=-2147483638,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/6/2019 5:00:55 PM - set raw streaming=False,current mode=DOP
11/6/2019 5:00:58 PM - remove eos 2=-2147483641
11/6/2019 5:00:58 PM - remove eos done
11/6/2019 5:00:58 PM - close stream=False
11/6/2019 5:00:58 PM - close stream handle=0
11/6/2019 5:00:58 PM - is same settings:: chans=2,2; freq=352800,352800
11/6/2019 5:00:58 PM - play=False,output=-2147483641,stream in mixer=False
11/6/2019 5:00:58 PM - play is paused=False
11/6/2019 5:00:58 PM - assign channel before=-2147483641,after=-2147483638,mode=DOP,started=True
11/6/2019 5:00:58 PM - assign channel:: chans=2,2; freq=352800,352800
11/6/2019 5:00:58 PM - assign channel set format and rate
11/6/2019 5:00:58 PM - assign channel undo pause
11/6/2019 5:00:58 PM - assign channel done
11/6/2019 5:00:58 PM - play startedTrue
11/6/2019 5:00:58 PM - set attrib=BASS_ATTRIB_VOL=1
11/6/2019 5:00:58 PM - Reset7
11/6/2019 5:00:58 PM - reset -2147483638
11/6/2019 5:00:58 PM - assign channel before=-2147483638,after=0,mode=DOP,started=True
11/6/2019 5:00:58 PM - assign channel paused
11/6/2019 5:00:58 PM - reset done
11/6/2019 5:01:35 PM - init chans=2
11/6/2019 5:01:35 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False,decode=False
11/6/2019 5:01:35 PM - set raw streaming=False,current mode=PCM
so it crashed at 4:13:32, and you restarted MB at 4:13:50, and loaded a MP3 file (I assume your player settings are set to restore the position of the player on restart)
I will have one more look at this tomorrow
frankcreed
Hi Steven,
You are correct about the restoring the player position upon restart.
Let me know if you would like me to try anything else.
frankcreed
Hi Steven,
WHATEVER YOU DID FIXED THE DSD CRASH PROBLEM !!!!!!
MB 3.3.7250 P
MB did *NOT* crash while playing this entire playlist, which mixed DSD128, DSD64, mp3 and flac files:
Here is the error log for the entire duration of the playlist (35+ minutes)
11/7/2019 4:18:40 PM - init chans=2
11/7/2019 4:18:40 PM - init=-2147483646,source rate=0, remove silence=False,is tempo=False,decode=False
11/7/2019 4:19:06 PM - close stream=False
11/7/2019 4:19:06 PM - close stream handle=0
11/7/2019 4:19:06 PM - Stop1=True
11/7/2019 4:19:06 PM - stop 0
11/7/2019 4:19:06 PM - assign channel before=0,after=0,mode=PCM,started=False
11/7/2019 4:19:06 PM - assign channel paused
11/7/2019 4:19:06 PM - stop: before=False
11/7/2019 4:19:06 PM - stop done
11/7/2019 4:19:07 PM - init=-2147483644,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/7/2019 4:19:07 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:19:07 PM - play=False,output=0,stream in mixer=False
11/7/2019 4:19:07 PM - play is paused=True
11/7/2019 4:19:07 PM - set bit streaming=BASS_SAMPLE_FLOAT, BASS_DSD_DOP, BASS_STREAM_DECODE, BASS_ASYNCFILE,current mode=PCM,new=DOP,chans=2,2,rate=352800,0
11/7/2019 4:19:07 PM - set raw streaming done
11/7/2019 4:19:07 PM - assign channel before=0,after=-2147483642,mode=DOP,started=False
11/7/2019 4:19:07 PM - assign channel undo pause
11/7/2019 4:19:07 PM - assign channel done
11/7/2019 4:19:07 PM - play started1=True
11/7/2019 4:22:08 PM - init=-2147483637,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/7/2019 4:22:12 PM - remove eos 2=-2147483642
11/7/2019 4:22:12 PM - remove eos done
11/7/2019 4:22:12 PM - close stream=True
11/7/2019 4:22:12 PM - close stream remove end sync
11/7/2019 4:22:12 PM - close stream remove mixer
11/7/2019 4:22:12 PM - close stream handle=0
11/7/2019 4:22:12 PM - IsSamePlaybackSettings rate=352800,352800, flags=1024,1024
11/7/2019 4:22:12 PM - play=False,output=-2147483642,stream in mixer=False
11/7/2019 4:22:12 PM - play is paused=False
11/7/2019 4:22:12 PM - play add to existing=False
11/7/2019 4:22:12 PM - play started2=True
11/7/2019 4:22:12 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:25:12 PM - init=-2147483631,source rate=2822400, remove silence=False,is tempo=False,decode=False
11/7/2019 4:25:16 PM - remove eos 2=-2147483642
11/7/2019 4:25:16 PM - remove eos done
11/7/2019 4:25:16 PM - close stream=True
11/7/2019 4:25:16 PM - close stream remove end sync
11/7/2019 4:25:16 PM - close stream remove mixer
11/7/2019 4:25:16 PM - close stream handle=0
11/7/2019 4:25:16 PM - IsSamePlaybackSettings rate=176400,352800, flags=1024,1024
11/7/2019 4:25:16 PM - Reset5
11/7/2019 4:25:16 PM - reset -2147483642
11/7/2019 4:25:16 PM - assign channel before=-2147483642,after=0,mode=DOP,started=True
11/7/2019 4:25:16 PM - assign channel paused
11/7/2019 4:25:16 PM - reset done
11/7/2019 4:25:16 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:25:16 PM - play=False,output=0,stream in mixer=False
11/7/2019 4:25:16 PM - play is paused=True
11/7/2019 4:25:16 PM - set bit streaming=BASS_SAMPLE_FLOAT, BASS_DSD_DOP, BASS_STREAM_DECODE, BASS_ASYNCFILE,current mode=DOP,new=DOP,chans=2,2,rate=176400,352800
11/7/2019 4:25:16 PM - set raw streaming stop
11/7/2019 4:25:16 PM - set raw streaming done
11/7/2019 4:25:16 PM - assign channel before=0,after=-2147483629,mode=DOP,started=False
11/7/2019 4:25:16 PM - assign channel undo pause
11/7/2019 4:25:16 PM - assign channel done
11/7/2019 4:25:16 PM - play started1=True
11/7/2019 4:29:10 PM - init=-2147483624,source rate=2822400, remove silence=False,is tempo=False,decode=False
11/7/2019 4:29:13 PM - remove eos 2=-2147483629
11/7/2019 4:29:13 PM - remove eos done
11/7/2019 4:29:13 PM - close stream=True
11/7/2019 4:29:13 PM - close stream remove end sync
11/7/2019 4:29:13 PM - close stream remove mixer
11/7/2019 4:29:13 PM - close stream handle=0
11/7/2019 4:29:13 PM - IsSamePlaybackSettings rate=176400,176400, flags=1024,1024
11/7/2019 4:29:13 PM - play=False,output=-2147483629,stream in mixer=False
11/7/2019 4:29:13 PM - play is paused=False
11/7/2019 4:29:13 PM - play add to existing=False
11/7/2019 4:29:13 PM - play started2=True
11/7/2019 4:29:13 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:33:08 PM - init=-2147483618,source rate=0, remove silence=False,is tempo=False,decode=False
11/7/2019 4:33:11 PM - remove eos 2=-2147483629
11/7/2019 4:33:11 PM - remove eos done
11/7/2019 4:33:11 PM - close stream=True
11/7/2019 4:33:11 PM - close stream remove end sync
11/7/2019 4:33:11 PM - close stream remove mixer
11/7/2019 4:33:11 PM - close stream handle=0
11/7/2019 4:33:11 PM - IsSamePlaybackSettings rate=44100,176400, flags=1024,0
11/7/2019 4:33:11 PM - Reset5
11/7/2019 4:33:11 PM - reset -2147483629
11/7/2019 4:33:11 PM - assign channel before=-2147483629,after=0,mode=DOP,started=True
11/7/2019 4:33:11 PM - assign channel paused
11/7/2019 4:33:11 PM - reset done
11/7/2019 4:33:11 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:33:11 PM - play=False,output=0,stream in mixer=False
11/7/2019 4:33:11 PM - play is paused=True
11/7/2019 4:33:11 PM - set bit streaming=BASS_SAMPLE_FLOAT, BASS_STREAM_DECODE, BASS_ASYNCFILE,current mode=DOP,new=PCM,chans=2,2,rate=44100,176400
11/7/2019 4:33:11 PM - set raw streaming stop
11/7/2019 4:33:11 PM - set raw streaming done
11/7/2019 4:33:11 PM - assign channel before=0,after=-2147483616,mode=PCM,started=False
11/7/2019 4:33:11 PM - assign channel undo pause
11/7/2019 4:33:11 PM - assign channel done
11/7/2019 4:33:11 PM - play started1=True
11/7/2019 4:37:33 PM - init=-2147483611,source rate=2822400, remove silence=False,is tempo=False,decode=False
11/7/2019 4:37:36 PM - remove eos 2=-2147483616
11/7/2019 4:37:36 PM - remove eos done
11/7/2019 4:37:36 PM - close stream=True
11/7/2019 4:37:36 PM - close stream remove end sync
11/7/2019 4:37:36 PM - close stream remove mixer
11/7/2019 4:37:36 PM - close stream handle=0
11/7/2019 4:37:36 PM - IsSamePlaybackSettings rate=176400,44100, flags=0,1024
11/7/2019 4:37:36 PM - Reset5
11/7/2019 4:37:36 PM - reset -2147483616
11/7/2019 4:37:36 PM - assign channel before=-2147483616,after=0,mode=PCM,started=True
11/7/2019 4:37:36 PM - assign channel paused
11/7/2019 4:37:36 PM - reset done
11/7/2019 4:37:36 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:37:36 PM - play=False,output=0,stream in mixer=False
11/7/2019 4:37:36 PM - play is paused=True
11/7/2019 4:37:36 PM - set bit streaming=BASS_SAMPLE_FLOAT, BASS_DSD_DOP, BASS_STREAM_DECODE, BASS_ASYNCFILE,current mode=PCM,new=DOP,chans=2,2,rate=176400,44100
11/7/2019 4:37:36 PM - set raw streaming stop
11/7/2019 4:37:36 PM - set raw streaming done
11/7/2019 4:37:36 PM - assign channel before=0,after=-2147483609,mode=DOP,started=False
11/7/2019 4:37:36 PM - assign channel undo pause
11/7/2019 4:37:36 PM - assign channel done
11/7/2019 4:37:36 PM - play started1=True
11/7/2019 4:41:21 PM - init=-2147483601,source rate=0, remove silence=False,is tempo=False,decode=False
11/7/2019 4:41:24 PM - remove eos 2=-2147483609
11/7/2019 4:41:24 PM - remove eos done
11/7/2019 4:41:24 PM - close stream=True
11/7/2019 4:41:24 PM - close stream remove end sync
11/7/2019 4:41:24 PM - close stream remove mixer
11/7/2019 4:41:24 PM - close stream handle=0
11/7/2019 4:41:24 PM - IsSamePlaybackSettings rate=44100,176400, flags=1024,0
11/7/2019 4:41:24 PM - Reset5
11/7/2019 4:41:24 PM - reset -2147483609
11/7/2019 4:41:24 PM - assign channel before=-2147483609,after=0,mode=DOP,started=True
11/7/2019 4:41:24 PM - assign channel paused
11/7/2019 4:41:24 PM - reset done
11/7/2019 4:41:24 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:41:24 PM - play=False,output=0,stream in mixer=False
11/7/2019 4:41:24 PM - play is paused=True
11/7/2019 4:41:24 PM - set bit streaming=BASS_SAMPLE_FLOAT, BASS_STREAM_DECODE, BASS_ASYNCFILE,current mode=DOP,new=PCM,chans=2,2,rate=44100,176400
11/7/2019 4:41:24 PM - set raw streaming stop
11/7/2019 4:41:25 PM - set raw streaming done
11/7/2019 4:41:25 PM - assign channel before=0,after=-2147483599,mode=PCM,started=False
11/7/2019 4:41:25 PM - assign channel undo pause
11/7/2019 4:41:25 PM - assign channel done
11/7/2019 4:41:25 PM - play started1=True
11/7/2019 4:46:21 PM - init=-2147483594,source rate=5644800, remove silence=False,is tempo=False,decode=False
11/7/2019 4:46:24 PM - remove eos 2=-2147483599
11/7/2019 4:46:24 PM - remove eos done
11/7/2019 4:46:24 PM - close stream=True
11/7/2019 4:46:24 PM - close stream remove end sync
11/7/2019 4:46:24 PM - close stream remove mixer
11/7/2019 4:46:24 PM - close stream handle=0
11/7/2019 4:46:24 PM - IsSamePlaybackSettings rate=352800,44100, flags=0,1024
11/7/2019 4:46:24 PM - Reset5
11/7/2019 4:46:24 PM - reset -2147483599
11/7/2019 4:46:24 PM - assign channel before=-2147483599,after=0,mode=PCM,started=True
11/7/2019 4:46:24 PM - assign channel paused
11/7/2019 4:46:24 PM - reset done
11/7/2019 4:46:24 PM - set attrib=BASS_ATTRIB_VOL=1
11/7/2019 4:46:24 PM - play=False,output=0,stream in mixer=False
11/7/2019 4:46:24 PM - play is paused=True
11/7/2019 4:46:24 PM - set bit streaming=BASS_SAMPLE_FLOAT, BASS_DSD_DOP, BASS_STREAM_DECODE, BASS_ASYNCFILE,current mode=PCM,new=DOP,chans=2,2,rate=352800,44100
11/7/2019 4:46:24 PM - set raw streaming stop
11/7/2019 4:46:24 PM - set raw streaming done
11/7/2019 4:46:24 PM - assign channel before=0,after=-2147483592,mode=DOP,started=False
11/7/2019 4:46:24 PM - assign channel undo pause
11/7/2019 4:46:24 PM - assign channel done
11/7/2019 4:46:24 PM - play started1=True
11/7/2019 4:48:29 PM - pause=True
11/7/2019 4:50:45 PM - play=True,output=-2147483592,stream in mixer=True
11/7/2019 4:50:45 PM - play is paused=True
11/7/2019 4:50:45 PM - pause=False
11/7/2019 4:56:35 PM - remove eos 2=-2147483592
11/7/2019 4:56:35 PM - remove eos done
11/7/2019 4:56:35 PM - close stream=True
11/7/2019 4:56:35 PM - close stream remove end sync
11/7/2019 4:56:35 PM - close stream remove mixer
11/7/2019 4:56:35 PM - close stream handle=0
11/7/2019 4:56:35 PM - Stop1=True
11/7/2019 4:56:35 PM - stop -2147483592
11/7/2019 4:56:35 PM - assign channel before=-2147483592,after=0,mode=DOP,started=True
11/7/2019 4:56:35 PM - assign channel paused
11/7/2019 4:56:35 PM - stop: before=True
11/7/2019 4:56:35 PM - bass stop -2147483592
11/7/2019 4:56:35 PM - bass free -2147483592
11/7/2019 4:56:35 PM - bass free done
11/7/2019 4:56:35 PM - stop done
frankcreed
whoops - hit 'post' instead of 'preview' :-)
Thank you so much for your time to debug this issue !!!!!!
thats good news.
This is the updated patch version with the fix in it:
also, if anyone has a device that supports DSD raw, I would appreciate comment on whether that also works
frankcreed
Hi Steven,
I don't know what happened, but the NON-debug ver 3.3.7250 P crashes when trying to play a DSD song - when you select a DSD file, MB crashes without playing a single note!!!!!
NOTE: the DEBUG version 3.3.7250 P works fine !?!?!?!
Here is the crash report from the NON-DEBUG ver 3.3.7250
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   MusicBee.exe
  Application Version:   3.3.7250.34208
  Application Timestamp:   5dc46a2d
  Fault Module Name:   bassasio.dll
  Fault Module Version:   1.4.0.2
  Fault Module Timestamp:   5d4acb07
  Exception Code:   c00000fd
  Exception Offset:   000061b7
  OS Version:   6.3.9600.2.0.0.256.4
  Locale ID:   1033
  Additional Information 1:   05ef
  Additional Information 2:   05ef80be9b29e57f85a38245eb9a8715
  Additional Information 3:   cb30
  Additional Information 4:   cb30b67aeca022c7cbbc84ea44669e87
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
  C:\WINDOWS\system32\en-US\erofflps.txt
was the initial song loaded on startup (due to the restore position setting) a DSD file?
