Author Topic: MusicBee auto closes at the end of a DSD song  (Read 11467 times)
frankcreed
Hi Steven,
First of all, I'm not sure what settings I had that caused DSD files to be sent as PCM to my DAC, but that problem is now resolved.
However, I'm still seeing MB crash after playing the first *.dsf file (with another *.dsf file next in the playlist)
MB 3.3.7243 P
Problem signature:
  Problem Event Name:   APPCRASH
  Application Name:   MusicBee.exe
  Application Version:   3.3.7243.38622
  Application Timestamp:   5dbb5229
  Fault Module Name:   ntdll.dll
  Fault Module Version:   6.3.9600.18895
  Fault Module Timestamp:   5a4b127e
  Exception Code:   c0000005
  Exception Offset:   0001de33
  OS Version:   6.3.9600.2.0.0.256.4
  Locale ID:   1033
  Additional Information 1:   5861
  Additional Information 2:   5861822e1919d7c014bbb064c64908b2
  Additional Information 3:   6fbe
  Additional Information 4:   6fbe6bde2701766d81cbca0597a5fa35
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
  C:\WINDOWS\system32\en-US\erofflps.txt
in the musicbee asio configuration (in player prefs), if you change the bitstreaming mode to PCM, does it work then?
I just noticed there is a more recent version of bassasio.dll, so its also worth using it to see if that solves the issue
https://www.mediafire.com/file/lriuw3zso0nbioy/bassasio.dll/file
copy to the folder that musicbee is installed
frankcreed
Hi Steven,
I'll try the new version of bassasio tomorrow, but to answer your original question:
Yes, if I select 'Convert to PCM' on asio player prefs, I can play as many *.dsf files as I want without issues.  When I select the 'DOP' option, that's when I can only play 1 dsd file before MB crashes...
frankcreed
Hi Steven,
Unfortunately, MB crashes after playing a single dsf file with the latest bassasio.dll, 'Stream DSD data as PCM (DOP)' in ASIO player prefs.
MB ver: 3.3.7246 P
bassasio.dll: 1.4.0.2
Problem signature:
  Application Version:   3.3.7246.27227
  Application Timestamp:   5dbeedae
  Locale ID:   1033
Could you run this debug version with DOP enabled, and perform the steps for it to crash. Then send me all the new info in the error log without doing any other actions so the last item in the log will be just before it crashes
https://www.mediafire.com/file/2g8a3cud256m1so/MusicBeeDebugDSD.zip/file
replace the existing installed musicbee.exe file
Last Edit: November 04, 2019, 07:15:13 PM by Steven
frankcreed
Hi Steven,
Got the same crash after playing a single DSD file.  Here is the error log info:
MB ver: 3.3.7247 P
11/5/2019 8:43:44 AM - E:\Frank's Music\:Thread was being aborted.
11/5/2019 8:45:03 AM - init chans=2
11/5/2019 8:45:04 AM - init=-2147483646,source rate=0, remove silence=False,is tempo=False
11/5/2019 8:45:04 AM - set raw streaming=False,current mode=PCM
11/5/2019 8:45:04 AM - init=-2147483645,source rate=0, remove silence=False,is tempo=False
11/5/2019 8:45:07 AM - close stream=False
11/5/2019 8:45:07 AM - close stream handle=0
11/5/2019 8:46:01 AM - init=-2147483644,source rate=5644800, remove silence=False,is tempo=False
11/5/2019 8:46:01 AM - set raw streaming=False,current mode=DOP
11/5/2019 8:46:01 AM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 8:46:01 AM - play=False,output=0,stream in mixer=False
11/5/2019 8:46:01 AM - play is paused=False
11/5/2019 8:46:01 AM - assign channel before=0,after=-2147483644,mode=DOP,started=False
11/5/2019 8:46:01 AM - assign channel:: chans=2,2; freq=352800,0
11/5/2019 8:46:01 AM - assign channel set format and rate
11/5/2019 8:46:01 AM - assign channel undo pause
11/5/2019 8:46:01 AM - assign channel done
11/5/2019 8:46:01 AM - play startedTrue
11/5/2019 8:46:01 AM - init=-2147483640,source rate=5644800, remove silence=False,is tempo=False
11/5/2019 8:46:01 AM - init=-2147483639,source rate=5644800, remove silence=False,is tempo=False
11/5/2019 8:46:01 AM - set raw streaming=False,current mode=PCM
11/5/2019 8:46:12 AM - close stream=False
11/5/2019 8:46:12 AM - close stream handle=0
11/5/2019 8:49:02 AM - init=-2147483638,source rate=2822400, remove silence=False,is tempo=False
11/5/2019 8:49:02 AM - set raw streaming=False,current mode=DOP
11/5/2019 8:49:05 AM - remove eos 2=-2147483644
11/5/2019 8:49:05 AM - remove eos done
11/5/2019 8:49:05 AM - close stream=False
11/5/2019 8:49:05 AM - close stream handle=0
11/5/2019 8:49:05 AM - is same settings:: chans=2,2; freq=176400,352800
11/5/2019 8:49:05 AM - Reset5
11/5/2019 8:49:05 AM - reset -2147483644
11/5/2019 8:49:05 AM - assign channel before=-2147483644,after=0,mode=DOP,started=True
11/5/2019 8:49:05 AM - assign channel paused
11/5/2019 8:49:05 AM - reset done
11/5/2019 8:49:05 AM - free -2147483644
11/5/2019 8:49:05 AM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 8:49:05 AM - play=False,output=0,stream in mixer=False
11/5/2019 8:49:05 AM - free done
11/5/2019 8:49:05 AM - play is paused=True
11/5/2019 8:49:05 AM - assign channel before=0,after=-2147483638,mode=DOP,started=True
11/5/2019 8:49:05 AM - assign channel:: chans=2,2; freq=176400,352800
11/5/2019 8:49:38 AM - init chans=2
11/5/2019 8:49:39 AM - init=-2147483646,source rate=0, remove silence=False,is tempo=False
11/5/2019 8:49:39 AM - set raw streaming=False,current mode=PCM
11/5/2019 8:49:39 AM - init=-2147483645,source rate=0, remove silence=False,is tempo=False
11/5/2019 8:49:41 AM - close stream=False
11/5/2019 8:49:41 AM - close stream handle=0
lux1o
if i press crl+S
before the song finish then i can play multiple tracks continually
Silviu
For me, it works only if I check Controls>Crossfade (or in Preferance). Not very normal  :(
Thanks. I can see the wavebar you have displayed might be related to the issue, so could you try with it disabled or removed? You should restart MB with the wavebar removed before you do the test. And send me the log as before.
Also I can see the following file had a different rate which is fine, but make sure you do the same test
To anyone else with issue, if you could try the same - including running the debug version then it will be helpful
Last Edit: November 05, 2019, 05:45:08 PM by Steven
frankcreed
Hi Steven,
I disabled the wavebar, re-started MB (just to be sure), and MB crashed same as before (good thing I like this song :-))
11/5/2019 1:12:41 PM - init chans=2
11/5/2019 1:12:42 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:12:42 PM - set raw streaming=False,current mode=PCM
11/5/2019 1:12:43 PM - init=-2147483641,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:12:43 PM - set raw streaming=False,current mode=PCM
11/5/2019 1:12:43 PM - init=-2147483640,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:12:45 PM - close stream=False
11/5/2019 1:12:45 PM - close stream handle=0
11/5/2019 1:13:28 PM - E:\Frank's Music\:Thread was being aborted.
11/5/2019 1:13:28 PM - close stream=False
11/5/2019 1:13:28 PM - close stream handle=0
11/5/2019 1:13:28 PM - Stop1=True
11/5/2019 1:13:28 PM - stop 0
11/5/2019 1:13:28 PM - assign channel before=0,after=0,mode=PCM,started=False
11/5/2019 1:13:28 PM - assign channel paused
11/5/2019 1:13:28 PM - stop: before=False
11/5/2019 1:13:28 PM - stop done
11/5/2019 1:13:29 PM - dispose
11/5/2019 1:13:29 PM - stop: before=False
11/5/2019 1:13:29 PM - reset channels=0
11/5/2019 1:13:29 PM - reset channels done
11/5/2019 1:13:35 PM - init chans=2
11/5/2019 1:13:36 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:13:36 PM - set raw streaming=False,current mode=PCM
11/5/2019 1:13:49 PM - close stream=False
11/5/2019 1:13:49 PM - close stream handle=0
11/5/2019 1:13:49 PM - Stop1=True
11/5/2019 1:13:49 PM - stop 0
11/5/2019 1:13:49 PM - assign channel before=0,after=0,mode=PCM,started=False
11/5/2019 1:13:49 PM - assign channel paused
11/5/2019 1:13:49 PM - stop: before=False
11/5/2019 1:13:49 PM - stop done
11/5/2019 1:13:50 PM - init=-2147483641,source rate=5644800, remove silence=False,is tempo=False
11/5/2019 1:13:50 PM - set raw streaming=False,current mode=DOP
11/5/2019 1:13:50 PM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 1:13:50 PM - play=False,output=0,stream in mixer=False
11/5/2019 1:13:50 PM - play is paused=True
11/5/2019 1:13:50 PM - assign channel before=0,after=-2147483641,mode=DOP,started=False
11/5/2019 1:13:50 PM - assign channel:: chans=2,2; freq=352800,0
11/5/2019 1:13:50 PM - assign channel set format and rate
11/5/2019 1:13:50 PM - assign channel undo pause
11/5/2019 1:13:50 PM - assign channel done
11/5/2019 1:13:50 PM - play startedTrue
11/5/2019 1:16:51 PM - init=-2147483638,source rate=2822400, remove silence=False,is tempo=False
11/5/2019 1:16:51 PM - set raw streaming=False,current mode=DOP
11/5/2019 1:16:54 PM - remove eos 2=-2147483641
11/5/2019 1:16:54 PM - remove eos done
11/5/2019 1:16:54 PM - close stream=False
11/5/2019 1:16:54 PM - close stream handle=0
11/5/2019 1:16:54 PM - is same settings:: chans=2,2; freq=176400,352800
11/5/2019 1:16:54 PM - Reset5
11/5/2019 1:16:54 PM - reset -2147483641
11/5/2019 1:16:54 PM - assign channel before=-2147483641,after=0,mode=DOP,started=True
11/5/2019 1:16:54 PM - assign channel paused
11/5/2019 1:16:54 PM - reset done
11/5/2019 1:16:54 PM - free -2147483641
11/5/2019 1:16:54 PM - free done
11/5/2019 1:16:54 PM - set attrib=BASS_ATTRIB_VOL=1
11/5/2019 1:16:54 PM - play=False,output=0,stream in mixer=False
11/5/2019 1:16:54 PM - play is paused=True
11/5/2019 1:16:54 PM - assign channel before=0,after=-2147483638,mode=DOP,started=True
11/5/2019 1:16:54 PM - assign channel:: chans=2,2; freq=176400,352800
11/5/2019 1:17:47 PM - init chans=2
11/5/2019 1:17:48 PM - init=-2147483643,source rate=0, remove silence=False,is tempo=False
11/5/2019 1:17:48 PM - set raw streaming=False,current mode=PCM
It still looks like its opening a wavebar according to that log.
But in any case, I have fixed the wavebar bug. However I am uncertain that is the actual cause of the crash
This is not a debug version:
If it still doesnt work I can try one more thing
Silviu
No, for sure. I never activated the wavebar, however, since some months ago MB began to crash.
frankcreed
Hi Steven,
I turned off the spectrum and volume visualizer, and ran this new version - same crash.
MB 3.3.7248 P
I noticed something really odd - I have the right main panel showing track information.  At the end of the DSD song, the right main panel goes completely blank, and then this happens:
Problem signature:
  Application Version:   3.3.7248.33196
  Application Timestamp:   5dc1bf5e
  Locale ID:   1033
