Author Topic: Theatre mode "Artist Pictures" more pictures  (Read 19533 times)
stardepp
I like the screensaver theatre mode "Artist Pictures" very much, especially because it displays changing artist images. But the artist images are only changed once in 60 seconds. A song is on average 3 minutes long, so you only see three artist pictures per song.
In the folder
C:\Program Files (x86)\MusicBee\TheaterMode.List
I opened the file
Artist Pictures.xml
and edited this file:
The default setting is "50" for
<settings rotationPeriod="50" />
<theaterMode>
So value 50 means 60 seconds, I set this value to value 10 or to value 100, but the change of the artist pictures remained at 60 seconds.
So how can I change the value so that the artist images change every 10 or 20 seconds?
Freddy Barker
  • 🎧 MB 3.4.7628P
...how can I change the value so that the artist images change every 10 or 20 seconds?
My gallery pic rotation of 30 seconds is set in the element like this...
<element type="Gallery" x="24" y="24" widthDock="x:Panel.Right" width="-24" heightDock="y:Panel.89" height="0" aspectRatio="zoomKeep" fillColor="0,0,0,0" interval="30" tags="artist"></element>
Not sure, but I think 30 is the minimum to limit network activity...
Last Edit: October 13, 2019, 10:42:15 AM by Freddy Barker
stardepp
@Freddy Barker  Thank you very much for your answer. But where do I put your code exactly, in the
Artist Pictures.xml
You want me to put the line of code
<settings rotationPeriod="300" />
replace with your code or should I put your code at the end of this file or between
</element>
and
</root>
see screenshots:
Freddy Barker
  • 🎧 MB 3.4.7628P
<element type="Gallery" x="1" y="1" widthDock="Panel" width="-2" heightDock="Panel" height="-2" aspectRatio="zoomKeep" interval="30" tags="artist"></element>
Sorry I didn't make that very clear!!
The interval="30" needs to be added to the element <element type="Gallery" in the file Artist Picture.xml
as in the CODE above, (or you could just copy and paste into your "Artist Picture.xml")..
Probably best to REMOVE the
(as it may take precedence over the Gallery element setting).
Freddy
Last Edit: October 13, 2019, 01:09:45 PM by Freddy Barker
stardepp
@Freddy Barker Thank you for your effort. Now this theatre mode changes the artist's picture every 30 seconds. For testing I changed the value to 10 in the code line
interval="30"
Why doesn't this code react to the value of 10 seconds? If
interval="30"
means 30 seconds, then
interval="10"
should mean 10 seconds, right?
Freddy Barker
  • 🎧 MB 3.4.7628P
interval="10
Yes, you're correct, 10 WOULD be 10 seconds, but i'm sure @Steven restricted the minimum duration to 30 seconds to limit network traffic / activity...
Freddy
Freddy Barker
  • 🎧 MB 3.4.7628P
Yeah, well, I'm addicted to music 🎼🎶🔊💿🎤🎧📯🎸🎹🪕
Not sure about addicted, but I do love all sorts of music  :D
Last Edit: October 13, 2019, 06:40:38 PM by Freddy Barker
stardepp
Hello, Freddy.
Could you kindly help me on this subject again?
Since I have a new PC and forgot to make a backup of MusicBee, the above mentioned change is also gone.
I inserted it like this, but it doesn't work, I mean, the pictures don't change every 30 seconds. What have I done wrong? See first arrow: I have removed "<settings rotationPeriod="300" />". should I leave the empty line or remove it?
Freddy Barker
  • 🎧 MB 3.4.7628P
Hello stardepp,
My adivice, albeit too late, is always make backups  :D
I'm sure its still ok to remove the line <settings rotationPeriod="300" />, from the XML. and just leave the blank space, (unless someone knows different?).
Also, in the line of code that starts <element type="Gallery", you just need to change interval="60" to interval="30", in order to have the artist pic change every 30 seconds.
Freddy
stardepp
Yes I changed <element type="Gallery", you just need to change interval="60" to interval="30", but unfortunately the artist images are still not changed every 30 seconds, even if I removed the empty line from <settings rotationPeriod="300" />.
stardepp
The same is written in both lines, see arrows in the screenshot. Could the mistake have anything to do with this?
Freddy Barker
  • 🎧 MB 3.4.7628P
The second entry at the end of the page where your second red arrow is, (just before </root>), is not required, and should have displayed an error....
