Author Topic: enabled/disabled colouring malfunctions  (Read 2178 times)
The 'folders:' entry keeps it's colouring for disabled when enabled:
The settings for WMA encoding keep their enabled colouring when disabled:
thats right - the text is not directly editable ie. has to be done via the ... button
i will look at addressing that as I can see there is no code to disable the controls
edit:
thats done for v3.4
Last Edit: October 12, 2019, 06:26:59 PM by Steven
