Author Topic: Music Bee Doesn't Notify me to Update  (Read 1786 times)
ACardAttack
I have check for update at start checked, but I never get a notification to update musicbee and have to do it manually , any idea why?
I think that only applies to major version updates (such as 3.2 to 3.3), which are pretty few and far between.
And if you're using the MS Store version, there have been very few updates. The Store version will always be quite behind the Installer and Portable versions.
