Author Topic: Help Wanted!  (Read 9258 times)
any developers who might be interested to help out with MusicBee, I am particularily wanting help for the following:
- a windows .NET friendly interface to the Project M visualisers (I have not checked myself yet, but I gather VLC may have created a windows port so that might be a good starting point)
- implementation of lyrics plugin api for some of the specialist lyrics sites or for additional artwork providers (not as important)
- implementation of a UPnP server plugin (I have some useful info and code samples to get this started)
- implementation of a coverflow plugin (I would need to make some enhancements to the plugin API, so please contact me first)
please PM me if you are interested to help out
Last Edit: April 02, 2011, 01:58:05 PM by Steven
ild2
'Clementine' features ProjectM visualisation on Windows. It's GPLv3 open source. http://www.clementine-player.org/
jdunstangaren
Hi there,
I'd be interested in working on getting projectM up and going in musicbee (motivation is that milkdrop crashes my computer over and over). I don't really have extensive development experience but I used to code in VB6 and Java, so I think I *might* be able to manage it. If there's any other info you need from me feel free to ask.
Oh and I'm using visual studio express, so I'll use VB.net if I can and if not then I'll just have to teach myself C++.
-Joel
if you do go down the C++ route, make sure the interface you expose is .NET friendly.
I imagine one thing would need to MB to supply is a FFT analysis for the sound that is currently playing, and it will be no problem to add that to the MusicBee API. Just let me know what you need and i will try and accomodate it in the API.
Also you will need a way to add a panel to MusicBee which i will add to the API as well. But i will wait until you let me know what you need before doing anything
