Hey folks,
I've just opened Musicbee this morning and it just started giving me the error message below for some unknown reason.
I believe it might have something to do with "Auto Rate" function that I recently started using but I'm not sure. I set it to "Auto rate on startup" but I'm 100% sure if that's the issue or not.
If anyone has any ideas then I'd be very grateful for your suggestions!
The error messageMusicBee v3.3.7165.34193 (Win10.0), 14 Sep 2019 14:35:
at #=zsXh0R4CCpT7pZBgoKRmcG3k=.#=zSOyut3sNWdOy.OnKeyPress(KeyPressEventArgs #=zJ7PPolo=)
at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
at System.Windows.Forms.Control.ProcessKeyMessage(Message& m)
at System.Windows.Forms.Control.WmKeyChar(Message& m)
at #=zo$0d9RrNwxLojWhT74tUVMU=.WndProc(Message& #=zcoS3AB0=)
