Author Topic: Highlight the same tag area within tag editor  (Read 4278 times)
Freddy Barker
  • 🎧 MB 3.4.7628P
Que? There's only one newer version since 3.3.7115...
Currently, for me, Help > About shows: 3.3.7175 P  -  is that not, at least in part, the Version number?  ???
Files > Properties > Details shows 3.3.7175.30239 (24-08-2019 @ 16:59).
Freddy
Oh, right. I see what you mean. I meant there's only one more post since 7115 on the latest version thread for people to download.
I'm guessing the minor version number increases by one each time Steven recompiles a new version, and may not indicate a meaningful change.
Freddy Barker
  • 🎧 MB 3.4.7628P
Freddy
Thanks for response!!
I'm easily confused but I'm thinking v3.3.7115 to v3.3.7175 must equate to 70 changes / mods / edits / re-compiles / what-ever's - haha!
P.S I'm now at v3.3.7190  ???  (reaches for calculator)
Freddy
arbor_mute
Freddy Barker
  • 🎧 MB 3.4.7628P
This patch does not work in Lyrics tab.
Please check :D
Request for test, confirmed using 3.3.7199 P (17-09-2019 @ 18:20)
Lyricist and Lyrics text boxes loose focus after clicking next or previous track arrows!
Freddy
[@Admins - Should this thread be in Bugs as opposed to Wishlist?]
Last Edit: September 20, 2019, 11:09:54 AM by Freddy Barker
Freddy
Freddy
major and minor versions are defined by programmer. 3d number (build number) is usually (automatically assigned) number of days since the date .net 1.0 has been released.
Freddy Barker
  • 🎧 MB 3.4.7628P
Freddy
Freddy
It all makes sense now you've explained it, thanks  ;)
Going for the most mult-embedded post ever...
Freddy
Freddy
Freddy
Freddy
no, this one is the most mult-embedded :)
arbor_mute
Please check :D
Freddy
This does not work in the lyrics tab.
Currently I am using 3.3.7367 P.
Could you please check?
Last Edit: March 20, 2020, 08:01:14 AM by arbor_mute
You're posting in the wrong thread. This is a wishlist thread. You should post your issue in the bug reports section.
