Author Topic: "Click to Play" button.  (Read 1655 times)
JMW
Has anyone else found that the click to play button adds the album to the playing tracks in reverse order?  Is this an issue or have I changed a setting without realising it?
Thanks
can you send a link to your settings file (help/ support/ view settings)
JMW
I cant reproduce the issue using your settings. Infact the click to play button wasnt even enabled in the settings file you sent.
JMW
Sorry,  I had turned it off.  I re-linked the file with the setting turned on.  Thanks
Yes I enabled the click to play button but was not able to reproduce the issue, nor see how MB could sort the playing tracks in reverse order.
So I wont be able to help further
