Ah, OK, so media Monkey is another library like iTunes Library and Music Bee is? It is BOTH a mobile app AND a desk top library? I was thinking it was JUST a mobile app. Thx.
V
Hi, Varick.
Yes. MediaMonkey does what you searching for, with a few pros and cons.
Pros:* Nearly perfect 2-way-syncing via WiFi (also for unrooted devices), USB and directly SD. It syncs ratings, playcount/playdate, lyrics and edited/created playlists.
* Support for Android & iDevices and some exotics.
* A little bit easier to configure than Musicbee, and a lot easier than Foobar.
* Much more functionality than iTunes.
* Good support by developer and community (similar Musicbee), with a lot script extensions.
* MediaMonkey Android supports Android Auto and some nice things like Chromecast, multiple artist and multiple genre listing.
Cons:* For full functionality, you have to pay for MediaMonkey Gold AND ALSO MediaMonkey Android Pro. But prices are fair.
* You're completely bounded to MediaMonkey on Windows and Android, to run it correctly. That means syncing, playing, nearly everything has been done by MediaMonkey. If you use another player play/skipcounts won't increase/decrease. If you copy music to your Phone by another way, it won't work.
* In my opinion Musicbee and Foobar sounds a little bit better than MediaMonkey, because of used engine. Shouldn't be problematic unless you're not audiophil.
* Normalizing above 89-90dB distorted some of my songs. As long as you not normalize above those values, it shouldn't matter.
* AAC encoder is only available by paying an extra codec package. But it's not worth the money, cause it's no good encoder and sounds crap. Use built-in LAME for MP3, if you go lossy.
* MediaMonkey Windows design and usability comes a little old school, but with other skins, I can live with it.
* Not such a great customization level as Musicbee or Foobar.
* MediaMonkey is still a little bit rudimentary (e.g. no smartplaylists), but does what a player should. More features are also planned.
I used MediaMonkey first in 2003/4, but old one was buggy, killed a lot of my tags and so I was pissed and started using Musicbee, when it came out. While I was using my phone for music playback only since nearly one year, I went back to MediaMonkey for syncing. Mobile usability and syncing my playcount (because for autorate songs and make playlists based on listening history) is more important for me, than desktop playing. I also play sometimes music on partys (did it with both Musicbee and now again MediaMonkey) and experience is nearly similar. So, If you want the best desktop-only player/manager, with good usability, I suggest Musicbee. If you want a good all-in-one sync/playback solution, pay some bucks and go with MediaMonkey 4 Gold and MediaMonkey Android Pro. iTunes, I would never suggest, only for really novice Apple-fans.
