On my two monitor setup (on Windows 10) I've had a minor issue for a while where sometimes a thin strip of the right-hand edge of MusicBee (I generally run MusicBee fullscreen on the left monitor) appears on the left-hand side of the right monitor. It wasn't simply the window being too big for the monitor, as it looked like the strip was at least partly a duplication of what was correctly appearing on the right edge of the left monitor).
I've just installed 3.3 Update 1 (I was previously on 3.3) a few minutes ago and it looks like that issue might have improved, but I now have a more annoying issue where if MusicBee is the active window any click on anything else will do nothing, I have to alt-tab to another application after which it's fine.
I use the skin Bee78, is the another skin I should use to rule out it being a skin-specific issue?
