Author Topic: Arabic translation  (Read 18335 times)
Leonelle
Good evening
Here is full free of typos Arabic language file ready to use (matches Microsoft Arabic language terminology)...
https://drive.google.com/open?id=1apC7WOkl9vkZG_dWfijYL71duTYJxSkr
This for 3.2 MusicBee version
Version 1.0 of the file
Please feed me back
Thanks
Last Edit: August 18, 2019, 06:08:11 PM by Leonelle
Leonelle
Here is another debugged file https://drive.google.com/open?id=1Bu0Hhg1Le0T-ERRcEV_124U2aVxyeIyC (V1.1)
and I need clarification for these strings:
#Main.msg.Y[u# Y [unsynched]
#Main.msg.Y[s# Y [synched/unsynched]
#Main.msg.Y[s.2# Y [synched]
for future questions please ask on this topic:
https://getmusicbee.com/forum/index.php?topic=3408.0
These fields relate lyrics - if the track has lyrics, unsynched means static lyrics, and synched means lyrics that are timestamped and scroll to keep in synch with song as it plays
Leonelle
Arabic translation included the incremental 3.3 version (file version 1.2):
https://drive.google.com/open?id=16uxBV-fyxSWF_BRIn7bm4uXqS66EU2a6
Here are some pics of not translated strings:
https://ibb.co/ZJzTbyf
https://ibb.co/FXy6db2
An error shows up when click on the following:
#Main.msg.MBLLFoTo# <Language> Topic Forum
#Main.msg.MBLLFoToL# <Link>
Here are images of the issue:
https://ibb.co/G5bTWWw
https://ibb.co/hX6K2Gk
Leonelle
Error text:
MusicBee v3.3.7115.39210 (Win10.0), 17 Aug 2019 14:00:
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
   at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start()
   at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
   at #=znsWGdGTnNx5EUYKPaceFn7DMv1sd.#=zSHLbOYQ=(#=zaDBuhPavwZ_SrL$0gw== #=z7T0Cnzw=, Boolean #=z_LgwFfXlhpw0)
   at #=zhEwU3W9SkdyBdrteIWc$YDxY12mL.#=zgOvjo3Sh9q4Y.#=zgNsLMpWoUL0utSc1707ojB$asSYAs6Zwzg==(Object #=zjru7zck=, EventArgs #=zRXqKV0M=)
i've noted that you haven't translated "tags" tab header in tag editor.
Leonelle
The file is fully translated, take a look
Leonelle
Or mention the untranslated identifiers here
Last Edit: August 08, 2020, 12:04:50 PM by Leonelle
your file is missing some spaces for the tags identifier (I know it wasnt very good that i did that!)
if needs to be:
#Tag.ctl.Tags   # العلامات
i don't know correct id, but this is what i see in tag editor:
Leonelle
Thanks for your feedback
I actually reformatted the language file and removed the duplicated spaces, apparently the space has been removed before and after the hash "#"
Please -if possible- mention all the identifiers have spaces before the hash "#" sign.
Thanks
Leonelle
I found duplicated identifiers, one #tTag.msg.noch# and other #tTag.msg.Noch# I don't know if that matters or it is initially at this case.
If you searched the language (English) file you will find duplicate identifiers with same credential, I wonder if this normal
yes, it's normal. Steven periodically changes english wording of some strings. only last entry (if there are duplicates) matters.
Leonelle
Space issues have been resolved, and some strings have been added/updated (1.3)
https://drive.google.com/open?id=1EkWsMEHMhKzLBxsSxbnLdxycJKTkS7pZ
Last Edit: March 30, 2020, 04:33:12 PM by Leonelle
Leonelle
Hello...
New language translation debugging of the following strings:
#Rip.msg.Anvo#
#Rip.msg.rbvaf-#
Here is the new file: (1.4)
https://drive.google.com/open?id=1M_Ga8O2nnkjbwK8v1FlUSWns7fVdU2zk
Thanks
