Author Topic: Reference Site for Artist/Recording Details  (Read 7783 times)
schumann
I frequently would like to know details about a recording or artist, especially the identity of the song writer and the musicians on the track. The best site I have found is Wikipedia which is limited so wondering if any others might exist?
Thanks!
MusicBrainz is a great source for this info. And if they don't have it yet, you can add it yourself.
stardepp
TateB also made a good proposal:
I often like to read reviews for an album while listening to it, so this is a favourite for me:
https://www.google.com/search?q=<Artist>+<Album>+review
There are also user-defined links, such as Last.FM and others:
https://getmusicbee.com/forum/index.php?topic=28882.msg160891#msg160891
violinbzjc
Hey, sorry for bumping. Can you guys recommend me something for recording at home? I want to start exploring independently, but I don't know where to start...
I began home recording about two years ago but only recently found some valuable insights. Be patient and experiment until you're satisfied with the sound and setup.
Investing in a quality condenser mic makes a huge difference. Experiment with placement and settings, and find the sweet spot. Good noise-isolating headphones are a must for clear sound. Check out this article for more home recording tips.
Last Edit: November 06, 2023, 08:12:26 PM by violinbzjc
@ajbolton, @violinbzjc
Please create a thread in the Beyond MusicBee section as the comments both of you made have nothing to do with the thread you've replied to, nor with MB.
Thank you.
