Author Topic: File type support for M3U8 files  (Read 1711 times)
GermanKiwi
Hi there,
I'm using the M3U8 format for my playlists, and I've enabled "M3U8" at Preferences > Library > "exported playlists", which means that MusicBee nicely uses this format with the playlists it creates for me.
However, I noticed that the list of supported file types at Preferences > General > "file types" does not include M3U8. It only includes the M3U format.
This means the exported M3U8 files aren't automatically registered to MusicBee in Windows, and furthermore they don't use the icon set that I'm using with MusicBee.
I would like to request that M3U8 is added to the list of supported file types on the Preferences > General page, please.
Thanks!
right-click on m3u8 playlist in win explorer, open with..., musicbee, always use selected app?
