Author Topic: Single folder for all music files - will this result in limitations?  (Read 1779 times)
mm
I have built my music collection over the years, and have used the format:
artist-albumname-track#-trackname.wav
and kept everything in the one folder.
I haven't used an interface like Musicbee previously, but found one folder being convenient when accessing in Windows.
I have decided to put embed album cover art into each track (so no folder.jpg or cover.jpg).
Am I going to hit any limitations keeping it like this?
SkyZippr
Are all of your music files indeed .wav? Because as far as I remember .wav doesn't support embedded artwork.
Freddy Barker
  • 🎧 MB 3.4.7628P
I no longer use WAV files as tagging them can prove problematic, also the file sizes are a massive overkill. I think you will find that most MB users make FLAC their choice for lossless. I could be wrong, I was once in 1972  ;D
Regards: Freddy
As far as keeping your files in a single folder, that's fine with MusicBee if that's what you want to do.  Just be sure in that case you don't use any of the "auto-organize" features.  Actually, that's what I do too for all the files I keep in my displayed Library (which all have embedded artwork).  I do have a lot of Playlists composed of files resident OUTSIDE the single "Library" file folder, which is fine too.  The only folder I "monitor" is the one with the "mother lode" of files.  MusicBee lets you do it your way.
Last Edit: August 07, 2019, 12:12:45 AM by sveakul
mm
Regards: Freddy
Looks like converting to .flac is the way to go. When I started, flac was not an option.
A few of the titles have pages from the CD booklet, scans of the CD itself. I am wondering what to do with all these extra items.
Freddy Barker
  • 🎧 MB 3.4.7628P
Facilities to enable other images associated with tracks can be included here..
Highlight Track -
Edit / Artwork Tag /
Freddy
captain_paranoia
Well, eventually, you will hit the limit of how many files you can have in a Windows file system folder...
If you ever need to look in the windows folder, you will be scrolling for a long time...
I can see no benefit to a flat file organisation over a simple, two level, disc-based folder hierarchy of AlbumArtist\Album\track.wav with one folder per album.
That structure allows you to have a folder.jpg image for each album, and store riplogs for each album, and easily find, move, copy or re-rip any album.
If you wanted to adopt a folder hierarchy, MB can do it for you automatically, using the auto-organise function, using a suitable naming template, assuming your files have correct metadata tags. If they're not tagged properly. MB can be instructed to infer tags from your carefully-formed filenames.
Oh, and yes; convert your files to FLAC. Smaller, better tagging, but still bit-perfect reproduction.
Which for an NTFS volume is 4,294,967,295.
If you do have that many music files, you have far more important issues to address than how to tag them.
mm
I did look into this, and with NTFS file system, I will never hit the limit (Maximum number of files in a single folder: 4,294,967,295). FAT32 yes (Max files in single folder: 65,534).
You make a good argument for the folders option.
mm
Highlight Track -
Freddy
Keeping in mind that my music files are all stored in the one folder, with tracks stored in the format artist-album-track#-TrackName.flac
The kind off additional artwork I would want to be 'linking in' would be album booklet graphics etc (artwork specific to the album). Therefore I would not want to embed this into every track file.
Is there are way I can do this in MB?
I am thinking CD Booklet maybe in the form of  artist-album-CDBooklet01  artist-album-CDBooklet02_03 artist-album-CdBooklet 04_05 etc.
How would I go about linking this just once?
Freddy Barker
  • 🎧 MB 3.4.7628P
If you check the lower half of the Artwork tag you can add..
•  Album Cover
•  Cover Back
•  Leaflet Page
•  Media Label
•  Lead Artist
•  Conductor
•  Recording Location
...and a host of others, hitting the ADD button gives you the option of selecting your preferred image.
You need to check it out and experiment with some of the multitude of options available in MB
Freddy
Last Edit: August 08, 2019, 02:29:54 PM by Freddy Barker
captain_paranoia
Media is commonly stored on an external HDD. These are commonly formatted to FAT32, for compatibility with multiple devices and operating systems; FAT32 support is more widespread than NTFS.
The other arguments for a hierarchical file structure are much stronger...
mm
•  Album Cover
•  Cover Back
•  Leaflet Page
•  Media Label
•  Lead Artist
•  Conductor
Freddy
So in my case, I have an album with 10 tracks. The album cover is embedded in each of those 10 tracks.
Therefore if for example I wanted to add Leaflet Page, would I have to embed that into each of the 10 tracks, or is there a way to link this once without embedding (using some Musicbee database facility?
Also with leaflet page (and I will have a closer look), does this support say the 10 or so pages you may find in a CD booklet?
