I've been having a little trouble with the artwork of my files I send to my music player through syncing. I can't seem to find the option to transfer better quality artwork either embedded or copied to the destination folder. My files are in FLAC format with good quality artwork and I send them to my device through on the fly conversion to maximum quality mp3. Here's my problem, once converted and sent to my device, the artwork quality is pretty poor, looks blurry and textured. I've tried all the options
here* embed artwork
- I thought if I chose this option it will embed my current artwork and retain it's quality but no. It downsamples it to horrendous quality
- tried to resize it to higher px: 500, 800, 1000, 1200. Still no change to quality.
- I thought it would copy the good embedded artwork but no. The same muddy image would be saved on my device.
* copy to same folder as the music file
- same result as above
Any thoughts on a fix? I just discovered Device syncing. In the past I would convert my files first then copy the folder structure of my music collection onto the device. Very tedious but I had no problems with tags/artwork even when converted. Any help would be appreciated. Thanks!
