Hi there! New user to MusicBee here.
Every time that I want to sync my iPhone 6 with the iPod and iPhone Driver plug-in, it syncs everything, instead of only just new songs and songs that may have been modified, like if I changed the tags or album art. It also won't sync any music files that are read only, when I am pretty sure that iTunes is able to do this. Is there any way to fix that?
Also, is there any way to make MusicBee work like in iTunes, in that whenever the play count is changed, it doesn't keep having to modify the file? I have a plug-in called Additonal Tagging Tools, which is supposed to update the playcount, but it never syncs up. It just adds the playcount under Tags (2) and modifies the file every single time I listen to it. And is there any simple way to sync play count between iTunes and MusicBee, besides converting the library to an iTunes one and keep importing it? I really want to switch over but these differences are bothering me.
