Author Topic: Update Play Order  (Read 1203 times)
Coogan
I wish that the Update Play Order would only effect the playlist that I apply it to, not all of my other playlists.
Sometimes I'd like to have one particular playlist ordered by Artist/Title, while leaving my other playlists in the order they were.
Thank you.
Coogan
My MusicBee Version:
3.5.8878
the "Update Play Order" command only applies to the currently active playlist. There is no code to go through all the other tabs and also apply the command to other playlists that might be open
Coogan
Thanks Steven, I see what I did now.
I was in one of the playlist headers when I sorted by title and used the 'update play order'.
I should have done that in the Now Playing window.
All is working good.  My mistake.
3.5.8878
