Author Topic: Fresh green  (Read 12561 times)
andrea.ippo
It's still work in progress and it's based on Rotem's Asylum White (in fact, a lot of strings are still original).
I hope you like it :)
Download link: http://www.mediafire.com/?3iwi6yk3m59fxoc
Last Edit: March 09, 2011, 06:51:01 PM by andrea.ippo
Rotem K.
andrea.ippo
I like it.
And if you don't mind me asking, why not make it a dependent skin?
I'm not sure I understand it correctly, can I delete from my skin file all the unchanged skinning <element />s ?
Thanks
Rotem K.
That's right.
Just make sure to add to the root element the dependent code.
You might want to look at 'Pop Blue' as an example, http://getmusicbee.com/forum/index.php?topic=2227.0
Last Edit: March 07, 2011, 09:17:35 PM by Rotem K.
VX
I like the concept of the skin. :)
However, there is a small bug: in Mini Player View the buttons: "Show main window" and "Close" are invisible unless you hover over it.
Consider making the skin dependent and you'll get rid of such bugs right away  :)
andrea.ippo
Rotem K.
Andrea, the image elements that haven't been changed can be deleted too.
andrea.ippo
Thank you, now I could post the xml directly as pure text in my post   :D
Rotem K.
Haha :) Well look at it this way, the less lines there is in the dependent the easier it is to change from one color to the other - so maybe some other dude will post a different color based on your dependent one.
