I have done a search and can't find an explanation or solution to this behavior....so here I am looking for help from the experts.
When I edit either a single file or multiple files (same album) the volume adjustment and equaliser preset options are grayed out. I can check the boxes and a green check does appear, but no changes can be saved or applied. Checking the eq preset and choosing one of my eq presets doesn't effect the sound at all.
Am I doing something wrong? I have tried this with both flac files as well as mp3 files.
Any help/info would be greatly appreciated.
Thanks in advance.
