Author Topic: Musicbee pulling play counts from old Last FM account?  (Read 1053 times)
antwan2009
Hi - I’m trying to sync my play counts from Last FM, and specifically from a new account I set up this year. However, it still seems to be pulling from a very old account I had a number of years ago. Is there any way to ‘unlink’ it, as such? I am signed in to the new account, but suspect this may be a legacy issue from when I used this other account with it a long time ago.
click the last.fm icon to log out and then click it again - it should prompt for a username/password
if its still not working, close musicbee and then delete
C:\Users\Steven\AppData\Roaming\MusicBee\LastFmConnect.dat
and log back in again
antwan2009
Thanks for the reply - I've deleted the file, logged in and resynced play counts, but it still seems to be pulling old ones. Is there anywhere else it could be pulling the counts from?
Edit: I've found LastFmScrobble.txt in the roaming file, which has stored all of these plays, and I suspect is where Musicbee might be pulling from. Even after deleting it though, it still seems to find them somewhere!
Last Edit: July 14, 2019, 02:33:35 PM by antwan2009
the playcounts are cached in this file:
C:\Users\<your id>\AppData\Roaming\MusicBee\InternalCache\LastFmPlayCountCache.dat
