I know you've tried to answer this a thousand times, but,having just turned onto MusicBee (I love it), and being a simple-minded writer, I can't figger it out yet.
Briefly: My whole Itunes library was easily imported into MusicBee. An hour ago, I downloaded another MP3 piece of music, which automatically went into another directory (Downmusic), and could then be easily imported into Itunes.
So...I've tried every way to get it into MusicBee, but the closest I get it "Playlist", which is not the same as the original MusicBee library. Tried to add it onto the Music Bee directory in the Root Drive (but a message says I must update" the MusicBee library in library preferences). Have tried other stuff too,
Itunes was a snap: "Import new file", which I do, Is there anything on MusicBee equivalent to that? With an easy explanation!
Many thanks
