Author Topic: Can't sort music in auto playlist sourced from folders by dragging them  (Read 2755 times)
The Incredible Boom Boom
Hi
Searching i have found this topic
I have many auto playlist , and i haven't ever understood how sort them
should I sort each autoplayst ? I mean does musicbee remember the settings for each autoplaylist ?
and for simple playlist (i don't use very often) should sort separatly
thanks , take care
I think autoplaylist sorting settings are saved alongside the Custom View. Or it might be the Custom Layout.
Either way, you could save both and your sorting settings will follow.
