is anyone willing to run a debug version of MusicBee and this plugin so i can get to the bottom of what is going on?
I'll install the plugin later today and check it out. Also happy to run a debug!
Preliminary checks & report for current plugin version...
Using Media Control
The media keys all perform as expected, but ONLY Volume up or down displays the Media Control pop-up window.
I don't get double pause/play, next/previous issue, but the buttons on the pop-up do nothing.
Windows 10 Pro / Version 1903 / Build 18362.295
MusicBee v3.3.7175 P
MediaControl v1.0.1 [update 28/08/2019]
Check (1) Windows 10 Update hijacking.
Contol Panel > Programs > Default Programs > Set program access and computer defaults > Music player
(Probably been reset to Grove Music after Win 10 update?)
Click on default and select MusicBee from list.
Check (2) Chrome hijacking.
Disable "Google Play Music" or "Plex" Extensions from Chrome.
Check (3) Spotify hijacking.
Open Spotify > Display Option (settings) > Uncheck option "Desktop overlay when using media keys"
Freddy
