Hello Steven and others,
My problem in brief:
My customized fields PERFORMERS (and others) show greyed MIXED upon multiple selections - also if the content is NOT mixed, but exactly the same for all individual tracks.
I use the tab tag2 for customized fields for classical music.
Separate fields for vocalists, instrumentalists, choir, orchestra, conductor.
In the end I create (with ASR) a combination 'export' field PERFORMERS where all previous interpreters come together.
Since some time there is a strange error in those fields.
If I have (example) an opera with 25 tracks and I fill in ALL 25 track fields with the same info and then 'export' all of them to PERFORMERS, the performers field does NOT show the identical content for all interpreters, but says MIXED - which is incorrect because ALL are the same.
This happens with the individual fields as well (vocalists, instrumentalists etc).
That makes multiple checking/editing very complicated, because you can not SEE any details in the field. Must open 1 by 1, change, copy to the 24 other tracks if necessary 1 by 1.
Can you check this phenomenon please?
Thanks,
Wim
PS
See my separate related post about a customized field
