Oh, I think I see what you're getting at. You want to search the subfolders without seeing the subfolders.
I don't know, I feel like this is a pretty uncommon use case. The Computer node isn't meant to be a replacement for Windows Explorer. If you're doing that much searching, you should probably be using the library, instead.
