Author Topic: How can I sync my music on my phone ?  (Read 2581 times)
marine
Hi all !
I was looking for a way to sync my music on my phone (the way itunes works for example), I found that musicbee could do that but I didn't get how !..
If I understood right we can download MusicBee Wifi Sync on the play store but I am not using Android but an other system called /e/ (https://e.foundation). On the aurora store I use to download Android's app I can't find any musicbee wifi sync...
Could you give me some help ? I am stuck !
Thanks !
If the phone is not running the Android OS, then you can't use the WiFi Sync app.
If the phone can connect via USB to the computer where MB lives, you can do a wired sync. Take a look at the Wiki section for Device Management: https://musicbee.fandom.com/wiki/Devices
marine
Cool thanks ! I didn't know I could sync with USB , I'm gonna try that :)
