unfortunately i cant reproduce this issue so will leave it unsolvededit:if you send me a link to your settings file, i will see if its something specific with your setup (help/ support/ view settings)
I do agree there is an issue that for tracks of duration 1-3 seconds, you cannot make MusicBee go to the previous track ie. it can only replay the same track when pressing the hotkey, so i will fix that for v3.4 as its not straight forward to fix
