Author Topic: Manually Changing Song order in Playlist on an Ipod Classic 2.0  (Read 1983 times)
justinmoka
I read through the FAQ, and searched through the forum, to try to find previous iterations of this question.
I am using an Ipod Classic 2.0 with Musicbee. I would like to manually change the order of songs in a playlist. When I go to drag and drop the songs within the playlist, nothing happens. It doesn't stick. I can add and delete songs, but I cannot adjust the order. Is this a known limitation? Perhaps it is because my ipod is so old?
Any insight would be appreciated. Thanks.
Justin
Hi, welcome to the forum!
Are you trying to change the playlist in MusicBee or after it's on the device? If it's in MusicBee, you may need to be sure that it's sorted in "natural order" or "playlist order" before you try to drag & drop to reorder. Try displaying the # field in your playlist, that will tell you what order MusicBee thinks the tracks should be in.
justinmoka
Hi Psychoadept,
Thank you for responding. I have the ipod plugged in and I am viewing its playlists through Musicbee; that is where I am trying to manually change the order. I have it set to Natural order. The # is also displayed, so I can see the number, but when I drag and drop, nothing changes.
Incidentally, I also tried Mediamonkey, and this exact same thing happened.
Yeah, I think you're only going to be able to reorder the playlists from the MusicBee end. It's fairly impressive that you can sync an apple device at all, but i guess it works because it's an older one
If you can work with iTunes, you might want to try right clicking on the playlist name in iTunes> Copy to Play Order command to update the order.
After you re-adjust the order, right-click the playlist in the playlist navigator panel and follow List->Update Play Order.
justinmoka
Thanks to everyone who responded so far. Much appreciated.
It sounds like it may not be possible to do this with Musicbee, and later versions of iTunes really struggled with my old iPod. Do you know a place where I could (safely) download older versions of iTunes?
Roby
I can handle my iPod Classic very well without installing iTunes. I only installed the necessary drivers with CopyTransDriversInstaller. Works great with MusicBee.
Doing a forum search would've saved you a lot of time.
https://getmusicbee.com/forum/index.php?topic=18506.0
