Author Topic: volume control under asio  (Read 975 times)
lux1o
hy
someone can explain me how the volume control works when i use asio with dsp replayngain all turned off
if the flac files are sendt  untouched to my external usb dac/amplifier ?
very thanks
Lucio
CritterMan
  • Now with FiiO M11!
If the volume slider in MB is turned all the way up, yes. If you reduce the volume slider in MB at all, no.
