Author Topic: Highlighting  (Read 677 times)
tom
So I recently discovered the Highlighting feature and it sounds really cool and I've been toying around with it a little. Only thing is I can't get any of the colors to show up, unless I click the "text?" box. Otherwise no color related to the songs shows up anywhere. Does this have to do with the "icon" selection box? I don't have any icons in that folder that it brings you to so what's up with that? Does it color the icon instead? Is there something else I'm missing that it colors usually?
Thanks in advance.
Assuming you are looking to have it displayed when you have the main panel set in 'Tracks' view, you'll need to have the column 'Highlight' showing.
tom
That's what I figured but I can't find a way to do that......
Nevermind I must have missed something the first time. Thanks for the help!
