Author Topic: Find highest resolution itunes cover art  (Read 1079 times)
JMuller
It looks like the itunes artwork finder in MusicBee caps cover art resolution at 1200x1200 pixels. I was able to find higher resolution artwork with this website.
It would be great if there was an option to disable the cap.
Another thing I notice is that there are often no matches in the search for cover art. If I search for it manually with a simple google search, I get results. Maybe adding some options to the search (like what tags to search for and where) would help with this.
Last Edit: May 30, 2019, 01:14:29 AM by JMuller
Moshi_
  • http://www.last.fm/user/Moshi_
I've been wondering about the higher resolutions as well! Would like to download the highest possible resolution. Besides 1200x1200 looks small on my 4K TV.
