Author Topic: Any way to reverse the jump bar?  (Read 1708 times)
natswat
I order my music by most recently released (Year, descending) and this renders the jumpbar unusable. Is there any way to reverse it?
That looks like a bug.
I tried adding Year(Desc)/Album and sort by it, then the jump bar no longer works. But if I select Year/Album and tick Sort Descending at the bottom, then it works.
Also tried sorting by Album(Desc) and the jump bar doesn't work for that either. I'd suggest you file a bug report.
trying to reproduce this now and am not able to. Are you referring to custom sorts (as opposed to sorting on the column headers?) and which view are you using?
Thanks!
Year is now fixed. But Album(Desc) has a bug as it jumps to a next item.
For instance, if you click D, it jumps to C album on the right of D album.
OK. Though it's a bug, it won't really matter as few people would use a descending alphabetical order.
