Author Topic: Fine tuning info displayed  (Read 491 times)
pg111
Hi everybody,
As a newcomer to MusicBee (which I find is a great program) I need help to get started.
Beyond being a great music player, I think MB is great to help you learn about music, composers, artists, and works.
So what I need to know is how I can get the following display whenever I'm listening to any song.
I'd like to be able to see the following items on the same screen:
– artist's bio
– lyrics of the song
– name of the currently playing song (so I can easily edit it if necessary)
Can someone help me by providing guidance so I can get to the desired result?
Many thanks in advance.
Cheers
Patrick
Bio & lyrics can be displayed by using the Panel Configuration. It's the little box to the left of the search bar. From the right side, select an element you want. On the left side you'll see a red bar next to the panels into which your selected element will display. Experiment until you find a layout you like.
I also suggest browsing through the Wiki and while it's not up-to-the minute current, it'll provide a good foundation for learning MB. Especially check out the Anatomy of Music Bee section at https://musicbee.fandom.com/wiki/The_Anatomy_of_MusicBee
