Author Topic: MB_OpenFilterInTab Issues  (Read 3732 times)
zkhcohen
Hi Steven,
I'm trying to search/filter the library based on a search term. I'm using "MB_OpenFilterInTab", but I've noticed that the only comparison types are Is and IsSimilar. I would like to be able to filter MetaDataTypes using the 'contains' comparator.
Additionally, and I'm probably misunderstanding this functionality, I would like to be able to search multiple MetaDataTypes at once. Using MB_OpenFilterInTab with MetaDataType.TrackTitle and MetaDataType.AlbumArtist does not return results from both types.
Could you explain this format? Is this 'AND' by default and not 'OR'?
public delegate bool MB_OpenFilterInTabDelegate(MetaDataType field1, ComparisonType comparison1, string value1, MetaDataType field2, ComparisonType comparison2, string value2);
Any help or an enhancement would be excellent.
Thanks again,
Zach
EDIT: After further testing it searches for field1 and field2 simultaneously. Logically, it operates as 'AND'.
Last Edit: May 20, 2019, 12:07:53 PM by zkhcohen
the next 3.3 update has
        Is = 0
        IsNot = 1
        Contains = 4
        DoesNotContain = 5
        StartsWith = 6
        EndsWith = 7
        Similar = 20
its an AND condition
Last Edit: May 20, 2019, 09:58:28 PM by Steven
zkhcohen
        Is = 0
        IsNot = 1
        Contains = 4
        DoesNotContain = 5
        StartsWith = 6
        EndsWith = 7
        Similar = 20
This is fantastic. Thank you.
