Author Topic: High DPI Problem 288 DPI (300 % Zoom)  (Read 1890 times)
stax76
Hello,
something must have changed because I've used this dialog many times before without problems.
https://postimg.cc/Q9fdyfJM
stax76
Thanks for the quick help, much appreciated. The form is still a little bit higher than the working area and the confirm button is behind the task bar.
https://postimg.cc/kVfz3Q9x
stax76
30% of the bottom buttons are visible so it's usable now.
Suggestion:
if Height > Screen.WorkingArea.Height then Height = Screen.WorkingArea.Height
yes it already does that but i now realise its not accounting for the caption bar height - thats fixed for the next update
stax76
Thanks. MusicBee is too good, it's probably the only app that is really holding me back from trying Linux. :)
stax76
Works perfectly now, thanks!
There are a couple of minor High DPI glitches using 288 DPI.
My dream is to have a glitch free portable app (Windows/Linux) but that's far away, maybe it will never happen.
