I have A LOT of audiobooks and multi-disk teaching collections.
1...
When MB auto-populates the artist info, it is ALWAYS 100% wrong when it comes to audiobooks. Unless someone has an easy way to grab the artwork for this, it would be nice to see a "Is this the correct artwork?" popup or field upon initial population (when auto-rip is disabled) which would then go into the Search/Choose options if someone chooses "NO".
Would the custom weblinks be a possible solution for this? I had forgotten about them until I was reminded in another post.
2...
Have an option to populate the info from the previous rip/disc. When it comes to audiobooks, and MB having incorrect information, you have to manually type in the info for each disc. When you're dealing with anywhere from 5-12 discs, it gets mighty tedious.
