Author Topic: display Dialog Windows on MB screen @ Multiscreen Setup  (Read 1117 times)
KangNi
I'm using a multi screen setup with an beamer. Sometimes I'm experience the situation that MB open dialog windows on the second screen (the beamer) which is off usually. These dialog windows obviously does not represent an separate window instance, so they can't be focused either moved between the screens with WIN+LEFT/RIGHT keys. In this situation you HAVE TO switch on the second screen (the beamer) to manually drag'n'drop the dialog to the first screen where the MB window is located.
My wish is that MB open dialog windows AUTOMATICALLY on the screen where the MB main window is displayed/located.
Implementing an option therefore would be welcome too.
Thank You in advance.
Greetings.
Last Edit: May 04, 2019, 07:42:28 PM by KangNi
