Thanks for the reply. Yes, it's the place were I have all my music. I've run 2 different programs and both "said" that my disks don't have bad sectors.
However, more than a month with this problem I have solved it yesterday... Sord of...
I am using latest musicbee version in windows 7 and instead of opening only the file were all my music files are stored, I've opened it but selected all the subfiles in there instead and it worked. The computer didn't reboot and nothing happened. It could be a file there that is causing this but I don't know, if the programs that I've used said I had bad sectors I'd probably buy other disk...
Once again, thanks for the reply. Lets see if nothing happens again when I try to add new music files in the future.
Cheers.
