Hello All
I discover recently the fantasic MusicBee software, thanks a lot.
I would like to report an issue which is a bug I guess, in a dedicated case.
I spent a lot of time to realize
different combinaisons by using preferences & settings options, and spent time on
Internet & Forum to find a howto solution way.
I did not find the solution unfortunately and decited to raise here the issue.
The
album grouping definition field parameters are
not applied for a customized sorting case like by
Date Modified.
As a result Album covers (artwork) are
splits like duplicated, instead of be grouped (combined).
I would like to illustrate the issue by posting some screenshot of my configuration for a more clear understanding.
How to group tracks for a same album
under an unique Artwork display ?
Thanks a lot, sorry if I created a duplicate topic (btw there is not a defect tracker database I think).
Bests.
