Author Topic: Force multi value tags to split?  (Read 713 times)
Is there any way to force multi-value tags to split on the semicolons (particularly in AAC files), short of manually editing each file? Rescanning doesn't do it.
I'd try, using search & replace command, changing the semicolon to another character and then change them back.
That's a good idea, should definitely be easy with genres. Although I've thrown in the towel on AAC files. Converting them all to MP3. Yeah there a little quality loss, but not very much on VBR and it's worth it to spare myself the headaches with Picard, MusicBee's tag inspector, and other weirdness.
