First off, just want to give my sincerest thanks to the developer of this app. I've been searching for a powerful music player/manager for Windows forever, but I would always be turned away by how unpolished and dated many of them looked. MusicBee is as beautiful as a stock app, but includes more options than I'll probably ever know how to put to use, and I'm truly impressed and thankful.
My question is about customizing the app icon. I decided to download the Windows Store version, which I normally don't do, but since it was offered on the website and promised auto updates I decided to go for it. However I ran into a bit of a snag trying to change the app icon, as it seems you can't do this for apps downloaded from the Windows Store.
The Change Icon button in the Preferences does seem to change the icon up in the top-left corner next to the hamburger menu, but the taskbar and start menu icons won't change even after a restart, and Windows won't let me add the custom icon file I want to the folder that stores skins and icons (I'm assuming cause this is the UWP version, and those AppData folders are locked down).
And advice how to get around this? I suppose I could uninstall this version of MusicBee and go with the non-UWP one, but I set it up the way I like now and would rather not.
