Author Topic: Tracks not numbered getting a # in front of file name. Don't want that!  (Read 877 times)
djdalex
Is there a easy solution for this?
Vinyl lover / Vinyl ripper / Vinyl cleaning / Digitizing addict / Audio repair / Audacity lover / Clickrepair.net lover / MusicBee Newbee
What are you talking about?  Where and what steps are taken to get the result?
djdalex
When i add tracks to my library that are numered like 01, 02, A1, B3 everything is ok.
When i add tracks that are not numbered (because i dont want that for that track!) an # is added to the track name in the library.
https://www.dropbox.com/s/f0eu51is24fz3dk/%23musicbee.jpg?dl=0
It's doing this because this is what your renaming template is telling it to do!
You need to add an exception using the "Add Exception" button to your naming template for tracks without track numbers and then set up a separate naming structure for them!
djdalex
Thanks! Sounds easy but is pretty hardcore to me.
What is wrong with this?
https://www.dropbox.com/s/fay1an5i7t4pivq/not%20working.jpg?dl=0
