Author Topic: Remove all genres from the database  (Read 760 times)
Peermeneer
Hello ,
I added new genres to most of my songs.
But evry time I make a choice I see a bunch of old genres which I don't need and want to remove from te database so that they don't show up any more.
But how???
Who can help me please?
Thanks in advance for your reaction
Peter van den Tillaard
Where are you seeing the genres listed? Is it from the Genre field drop-down from within the Tag Editor? If not, please post a screenshot.
screenshots: https://getmusicbee.com/forum/index.php?topic=28168.0
If you are seeing them there, and they appear as you type, or see them in the drop-down, it means you still have track(s) that using the genre. Once all traces of the genre is removed from all tracks, the genre will disappear from the list.
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
I noticed that there is a huge "repository" of genre names in the Configuration.xml file in the main MB folder.  I have no idea when/where they might appear in a dialog box for selecting genres, as I do all my tagging externally.  Best to start with a screenshot like phred suggested.
Pingaware
Those are probably the values used to classify genres into genre categories, which can be customised somewhere in preferences (don't have MB on hand to state exactly where). They won't appear as suggestions unless you have a track tagged with them (as phred said).
Bold words in my posts are links unless expressly stated otherwise. Have fun with them!
