Author Topic: Search for Cover with Album Art Downloader  (Read 29521 times)
Based on the information here I just tested putting -f "Cover.jpg" -p "<Path>" at the end of my command line in MB's tools and it worked just fine.
Edit: In MP3Tag I used -f "Cover.jpg" -p "%_folderpath%"
I always wanted to do this but never thought about how to actually accomplish it before, so thanks for the inspiration.  Have a wonderful day!
Last Edit: February 05, 2021, 01:15:55 PM by frankz
Thanks frankz, that's it!  The <Path> parameter was the key.  So for Johan_A_M, my previous string adjusted for using this instead of a fixed path would be:
/ar "<Artist>" /al "<Album>" /t f,u /mn 300 /mx 3000 /o a- /ac /f "%artist% - %album%.%extension%" /p "<Path>"
Thanks to both frankz and sveakul. This is now working better than ever.
Johan_A_M
Thank you SO much!!
decard
Very much very helpfully this extension  :)  functions very well with my MusicBee version 3.3.7015.
Because I hear many rather unknown artists, I have searched in the past long with Google for a suitable album cover.
'Albumart' shortens this cover Searching uncommon.
In addition, this description also for laymen like me understandably
Many thanks for it  :)  :)  :)
ha! i have been trying to find out where all the hundreds of Albumart files that suddenly appeared at some time came from. what is the answer?
https://getmusicbee.com/forum/index.php?topic=39272.msg212144#msg212144
decard
that link is helpful for query re my auto-saving images (if it works as i want/hope); but it does not answer the question i raised directly above .... where did all these Albumart files suddenly appear from (before i was using MB)? they all have unique names which must be linked to specific track (i imagine - i haven't checked file Properties to check)
decard
https://sourceforge.net/projects/album-art/
I thoroughly love this cover search software.
Search Preview:
https://i.gyazo.com/b77c1882d4b8e40edd887a8948f90296.png
I setup:
A toolbar button in Musicbee that, based on the selected track, searches the artist and album in Album Art Downloader
Directions:
1. Open MusicBee Preferences and select the "Tools" tab
2. add the application path (mine is C:\Program Files\AlbumArtDownloader\AlbumArt.exe) {just click the button on the right side with three dots then navigate to the exe file}
3. Make sure you set the parameters to: "<Artist>"  "<Album>"
4. click Save
---- You can stop at this point and just right click the file and use the "Send To" feature ----
If you wish to add the toolbar button as I did:
5. Right click your toolbar then "Configure Toolbar"
6. Click the plus sign to add a new button command
7. click the three dots and Set the command to the "Send To: External Application (selected file) [your #]"
Mine was #3 because Audition and MediaInfo were apps 1 and 2...
If you like my dark theme, feel free to try it (Click Here)
thanks. i got this to work; but i am a tad bemused - when you create the Toolbar Button, although i labelled button AlbumArt, how did it know to use the AlbumArt exe? because i do not actually embed the exe into that link.
Because the Command line is pointed at External Application #3, which you can see in Step 3 of the directions has the application path specified.
