I am trying to get the plugin working. I have MusicBee 3.3.7141 P and Spotify Integration Plugin 2.0.2. I was able to copy the files to my plugins folder. When I go to Edit Preferences-Plugins-mb_Spotify_plugins there is a configure button however when I press it nothing happens.
I added the Spotify panel to a new Music bee view. It says "No Track Found" when I click on this I get "Bad ID"
If I click on The title header and select "Re-authenticate" I am taken to a Spotify webpage, I enter my credentials then I am taken to a a page:
http://localhost:4002/auth?access_token=...&token_type=Bearer&expireon this page I see the following:
Json tab: SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
Raw Data tab: OK - This window can be closed now
Headers:
Cache-Control no-store, no-cache, must-revalidate
Content-Encoding gzip
Content-Length 54
Content-Type application/json; charset=utf-8
Date Wed, 27 Nov 2019 05:13:03 GMT
Expires Mon, 26 Jul 1997 05:00:00 GMT
Keep-Alive timeout=15,max=99
Last-Modified Wed, 27 Nov 2019 05:13:03 GMT
Pragma no-cache
Server embedio/2.0
Accept text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Encoding gzip, deflate
Accept-Language en-US,en;q=0.5
Connection keep-alive
DNT 1
Host localhost:4002
Referer
http://localhost:4002/Upgrade-Insecure-Requests 1
User-Agent Mozilla/5.0 (Windows NT 10.0; rv:68.0) Gecko/20100101 Firefox/68.0
This is as far as I can get, if I go back to Spotify it still says "No Track found" so it doesn't look like it passes the credential back to MusicBee. What am I doing wrong? Any ideas?
Thanks.
